Hello!
I whant to change the ecu from 3B to AAN and use the 3B loom.
I have gathered some info about this swap but i saw some diferences between the S2 Central and SJM sites.
Pins1 from ABY at 1 site is for output stage ignition coil nr.1 and at the other is for nr.3
same about the pin nr.23
Somebody knows exactly wich is wich?
And i noticed that between the 3B and ABY the RPM and Reference sensors are in the oposite pins. This is right?
Thank You verry much!
All the best!
Eugen
All the best!
Eugen
