I have a problem I need help with!
My new build engine (AAN) is breathing oil in the head breating (behind the head) when I use the engine hard. It is a lot off oil.
The oil breating in the block is perfect and as it should be.
I have checked the cylinder compression and its the same all over! so no broken piston rings.Oil pressure is good also!
any ideas?
any ideas?
You are missing parts from the crankcase ventilation system. I think you really need to have a look at this:
