UrS4/6 Boost and oil pressure gauge options
  • Animal Mother
    • Jul 2007
    • 1135
    Here is one for all of the classy UrS4/6 owners.
    What boost and oil pressure gauge solutions do you use in your car? Do you have any pics you can post up?
    I now think I need a boost gauge and an oil pressure gauge (why didn't we get one of these as standard??).
    I have a few limitations/ideas. Your commments and ideas are most welcome.
    1. I don't mind using two of the centre vents.
    2. If I use the vents is there an off the shelf pod I could use. If not, I will take the vents out, fill them with wax and use a hole cutter.
    3. I don't want to use the 034 digi boost gauge.
    4. I don't mind losing the ashtray.
    5. I like the stock colours of the gauges but also like the smoked ones.
    6. I like Prosport gauges.
    7. I don't want to use the A-pillar.
    8.There are two spaces in the lower dash either side of the steering wheel, has anyone utilised this space. I don't fancy cutting holes in there though!
    Any thoughts?
    UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
    Triumph Daytona 955i - mmmmmm :fire:
    80 dag dag :driving:
  • PeteRR
    • 1326
    The UrS4 does have an oil pressure gauge (where I believe the volt gauge is in a UrS6), some knowledgable soul on here may be able to describe how to do a retro-fit of the UrS4's set-up if you wanted to go down that particular route.
    The UrS6 has the digital boost gauge too doesn't it?, though I know it's not the most accuarate thing in the world.
    • Animal Mother
      • Jul 2007
      • 1135
      It's alright. Well, actually, it's a bit rubbish to be honest.
      • Knight Rider S4
        • 3541
        As Pete says the UrS4 has oil pressure gauge already and with regard to the atmos boost gauge on the dash it is not that far out on mine (-1 bar)
        probably easiest thing would to do is change dash over for UrS4..would not do this myself as i think the S6 one looks better
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Animal Mother
          • Jul 2007
          • 1135
          Doubt that would be the easiest thing. Reckon it would be a PITA, never mind costly !
          I'm still thinking of using 2 vents with 2 gauges, although I would still like to hear other peoples comments and experiences on other ways of mounting gauges into the UrS4/6.
          • Knight Rider S4
            • 3541
            Very easy to change Clock/Gauges over(i speak from experience!!) ,cost maybe yes but just idea
            Your response comes across very rude..was this your intention?
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • topsparky
              • Oct 2005
              • 2014
              what about this then
              [IMG][/IMG]
              1. SHORT SHIFT KIT
              2. PORSCHE CAYENNE CALIPERS
              3. H & R SPRINGS
              4. BILSTEIN SHOXS
              5. NEW BUSHES AND HP2 STRUTS
              6. UPRATED HIGH OUTPUT COIL PACK
              7. ,3" turbo back s/s/ exhaust
              8. fmic fitted
              • Animal Mother
                • Jul 2007
                • 1135
                When you said change the dash over I thought you meant the entire dash not just the clocks/instruments. Is worth considering as I would retain one of the vents if I ent that route.
                Not in the slightest. You own an S4 not an S2 so why would I be rude to you?
                • Animal Mother
                  • Jul 2007
                  • 1135
                  [IMG][/IMG]
                  Where does that go?
                  Does it replace the entire set of vents?
                  What gauges are they?
                  • topsparky
                    • Oct 2005
                    • 2014
                    yes it replaces the 3 vents above the switches and radio
                    the gauges i've put in are egt ,boost ,fuel pressure
                    1. SHORT SHIFT KIT
                    3. H & R SPRINGS
                    4. BILSTEIN SHOXS
                    8. fmic fitted
                    • topsparky
                      • Oct 2005
                      • 2014
                      he's a slightly better picture
                      [IMG][/IMG]
                      1. SHORT SHIFT KIT
                      3. H & R SPRINGS
                      4. BILSTEIN SHOXS
                      8. fmic fitted
                      • Animal Mother
                        • Jul 2007
                        • 1135
                        Looks nice, kinda padded looking.
                        What brand of gauge are they?
                        Homemade using the original vent casing??
                        • topsparky
                          • Oct 2005
                          • 2014
                          the gauges are auto gauge stealth
                          got them from this guy
                          gauge place
                          he's a top fella
                          i made the gauge pod by taking all the vents out grip filling a piece of aluminium sheet
                          in and p38 filler to shape it to the same contour as the dash
                          i did have a carbon look sheet on
                          but it looked ****
                          as BRY pointed out
                          so i painted it satin black
                          i think it looks good
                          and can't wait to get my car back to fit it in
                          1. SHORT SHIFT KIT
                          3. H & R SPRINGS
                          4. BILSTEIN SHOXS
                          8. fmic fitted
                          • AndyP
                            • 6049
                            That's no way to talk about Dean
                            Seriously though, I've seen this and it looks really good
                            • topsparky
                              • Oct 2005
                              • 2014
                              atleast my bones don't whistle in the wind
                              twiggy
                              1. SHORT SHIFT KIT
                              3. H & R SPRINGS
                              4. BILSTEIN SHOXS
                              8. fmic fitted
