Hi all,
After spending 6 months visiting this excellent forum I dicided it was about time I started a thread.
Recently I purchased the BMC CDA for my 3b and after removing the original air box I found the cone and intake pipe were way to big (even just with the cone fitted I couldn't close the bonnet). So after refitting the air box I took the unit back to the supplier who then called the BMC head office. They looked into it and said that the only S2 they new that had the unit fitted was in Italy. They have decided to send a smaller model with different intake pipework which will arrive tommorow. (Will keep you posted on the results) and more info on the car in Italy.
The main problem with this unit is that our MAF's are facing into the bulk head and therfore the intake pipe needs to turn 180 deg using up more vital space.
Alun.
Alun.
