k27 7200, any use?
  • Animal Mother
    • Jul 2007
    • 1135
    k27 7200, any use?
    I've been offered a K27 7200, can I do anything with this on my UrS6?
    I have zero turbo technical knowledge.
    UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
    Triumph Daytona 955i - mmmmmm :fire:
    80 dag dag :driving:
    Lag Monster. Wrong flange.
    • Animal Mother
      • Jul 2007
      • 1135
      Cheers.
      No point fitting K27 cold side to K24 hot side? Or am I talking balcocks?
      • BRY
        • 3755
        The latter
        • s2driveruk
          • 12696
          @ BRY
          i think its as simple as RS2 unit from KKK or one of the Garrats....
          1992 3b S2 Coupe
          • Billman
            • 4129
            I dont think tha tthere is a K27 7200. Do you mean K24 7200 (RS2 Turbo?)
            Go Holset or Go RS4
            • S2_Dave
              • Aug 2005
              • 456
              If so, have a read of this thread, #51.
              David
              '91 3B S2 Coupe
              • Animal Mother
                • Jul 2007
                • 1135
                Yep there is.
                  Originally posted by Animal Mother
                  Yep there is.
                  LMAO
                  So you've taken the random numbers from the plate and put two together? when the number of the turbo is k27-3072
                  This has to be the funniest post I've read in ages
                  • A80Avant
                    • 10873
                    • Country: Greece
                    lol
                    • GazzaG60
                      • 4133
                      Originally posted by Jamo
                      LMAO
                      no need to take the piss and try and belittle people who openly say thay are not sure.
                      there was once and still will be days we are all not sure.
                      go for a garret based turbo. if you want a kkk based easy bolt-on then get a kkk flanged GT. otherwise save a few quid and go non BB. if you need a contact let em know
                      • Animal Mother
                        • Jul 2007
                        • 1135
                        Cheers for that.
                        Guess that this guy is wrong too as it is where I got the info and pics from. Plus this google search doesn't bring up many K27 7200 hits, honestly!
                        I think all of the "experts" on this forum are great!
                        • mcandmar
                          • Apr 2004
                          • 5118
                          If it’s from a 930 it won’t be a great at all, because the Porsche engine was air cooled they ran an oversize turbo rather gently to keep the temps down. Lots of lag, even with a 3.0 engine it had lots of lag. Best suited to hairy chested drivers from the 80's.
                          It’s also a dinosaur vs the garret stuff everybody’s fitting these days.
                          91CQ20v - Gone to a new home
                          93UR-S4 - The Magic Carpet
                          94S2Bus - The Emerald Express
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            I was given the links to these by another forum memeber, hope they help you aminal mother..
                            K27 compressor maps
                            Chef
                              I think that is a Porker number alright and if its K27 then yes it will be too laggy here. LOL at mcandmar 80s comment - brilliant.
                              I still say the best bolt-on turbo for the I5 is the RS2 item - it remains this day, the only turbo specifically designed for that engine so it does a fine job at the compromises between low-end tractability and max boost performance. True with factory ECU programming it is somewhat laggy and has on/off character but that can be greatly reduced with better software.
                              The newer generation of Garrett BB turbos are mindblowingly good it must be said - with even less lag and better top-end when properly setup. However they aren't true bolt-on due to the different oil, water and flange fitments - unless you get from a source that uses the KKK centre and has the right adapters for flanges etc. Ok I'm wavering here now, but if an RS2 turbo comes your way at the right price then go for it.
                              Paul
