turbocharging 2.3 20V (7A type)
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    Hi i wanna to asked you, if somebody have turbocharged 7A engine (2.3 20V) . Because in our country is too hard to find a good S2 car, so i thinking that i want turbochared this engine.
    Thanks a lot
    Tom
    Audi Coupe Quattro 2.3 20V
    it has been done, in fact Carlos on here is doing this project right now
    • Azman
      • 3205
      Depends low pressure turbo is an easy one, for the full blown thing it is a complete rebuild with custom pistons the works, but you will end up with a mega strong engine in the process.....
      Dark Grey Avant
      RS2 FARB
      Alloy Subframe Bushes
      • Azman
        • 3205
        Oh yes, supercharge the thing!!!!!!
        Dark Grey Avant
        RS2 FARB
        • Skull
          • 3506
          • Country: Slovenia
          what about an eaton compressor?
          Audi Quattro WR
          • Flat on my back
            • Jan 2007
            • 2449
            Very popular conversion in the USA, go on the motorgeek.com site and also check out 034motorsport.com. for parts.
            Carlos.
            • Tom_
              • Oct 2007
              • 1301
              Error404 : Carlos? Has he got his project on Project Room?
              Azman : i compared the low pressure turbo without changing pistons,conection rods,etc...
              Skull23 : compressor is good,but the turbo is a turbo. Take ,that the engine 7A has his full own power from 4 000 rpm/min , so i think that the using the turbo will be better for the use full potentional of the engine...
              Sry for my bad english
              • GazzaG60
                • 4133
                a 7a is a good staRT for FI.
                basically a vw16v engine + 1 pot.
                to do proper you need rods and pistons.
                the most important part is the ECU. its all about fuel and air and timing. turbo is a turbo and turbos all do a similar job its all about compromise between top end and bottom end.
                id go scats and wiseco's or JE.
                tubular and a gt or a t3/t04e 57 or 60 trim with a stage 3 0.63 hotside.
                stacked gaskets with arps will hold 400whp if the vw is anthing to go by but try t okeep torque below 350lbsft if you use the standard internals and 2-3 gaskets.
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Just here...only a very slow head building project at the moment, collecting parts for the engine.
                  Carlos.
                  • volcano rs
                    • Jun 2005
                    • 2265
                    rods are same for s2 and 7a
                    • Puglife
                      • Jun 2006
                      • 731
                      i'm turbo'ing my 7a lump and fitting into my UR quattro, but i wasn't sure if crank journals were different size to s2 (ABY/3B etc). Is it just custom pistons for the bore increase that are needed?
                      Jay - pug_life85@hotmail.com
                      1986 Audi UR quattro - WORK IN PROGRESS
                      1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                      • volcano rs
                        • Jun 2005
                        • 2265
                        rods crank are all the same just pistons are bigger
                        • Puglife
                          • Jun 2006
                          • 731
                          solves my issues there then
                          Best get buying some heavy duty parts
                          • Tom_
                            • Oct 2007
                            • 1301
                            http://www.s2forum.com/forum/showthread.php?t=22356
                            carlos , nice looking project, i hope that you finished this project soon I want to go this same way in future,but now i must learned and save the money on it
                            which ECU do u use? Standalone or piggyback?Can you write a list what u all change?thx and good luck
                            • Tom_
                              • Oct 2007
                              • 1301
                              so 7A rods,crank are same as a S2 ? really?
