Flywheels
  • 20Vcqdriver
    • 829
    Flywheels
    Simple question, Which is the lighter flywheel, the 7A or 3B and by how much? Converting from 7A to 3B and want to fit the lighter of the 2 flywheels. Thanks
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
  • mcandmar
    • Apr 2004
    • 5118
    3B is lighter. I posted the weights for flywheels a while back, will try and find them..
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • mcandmar
      • Apr 2004
      • 5118
      3B flywheel 10.5kg
      7A flywheel 11kg
      ABY flywheel 14kg
      3B pulley 4,280 grams
      7A pulley 4,350 grams
      ABY pulley 5,066 grams
      • 20Vcqdriver
        • 829
        Flywheels
        Thats great thanks, will leave 3B one attached and can now sort suitable clutch.
        • A80Avant
          • 10873
          • Country: Greece
          when going to a lighter flywheel,is it appropriate to always balance it with the crank again?
          • terrybullwon
            • Mar 2006
            • 8782
            Pefectly yes but if its a OEM Flywheel you will get away with it as its of a high standard. Saying that going from a dual mass to a singal mass maybe be different?
            I have lightened my 3B Fly quite alot and will be having it blanced.
            Chef
            • S2_Dave
              • Aug 2005
              • 456
              Hello "clatter". Hope you don't suffer with it like I do.
              David
              '91 3B S2 Coupe
              • Mark Halligan
                • 2001
                You are not alone
                My ally flywheel is great, but that rattle / clatter does take some getting used to...
                Mark - Modded
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Originally posted by Mark Halligan
                  You are not alone
                  I was warned, There is about 1 hours worth of work left to do just taking the burrs off really. I will post some pictures in my thread.
                  Chef
                  • raymor
                    • Sep 2003
                    • 597
                    What causes the extra noise on the Ally flywheel... I've got one sitting on the shelf ready to go.
                    How noisy is it, slighty annoying or plain irritating?
                    1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
                    1987 CQ85RS
                    1994 S2 Avant- Gone
                    1991 V8 -Gone, but lives on in the TDi and CQ
                    Fintray Hillclimb - 33.20s
                    Doune Hillclimb - 55.02s
                    Forrestburn Hillclimb - 52.61
                    • S2_Dave
                      • Aug 2005
                      • 456
                      AFAIK it's caused by tiny high frequency vibrations from the engine. Usually it's not an issue when there's more mass in the flywheel. Increasing idle will usually cure it, but then you also increase wear, particularly on cold startups. Some M3 boys found a concoction of gearbox oils helped to damp out about 90% of the clatter after going lightweight. It's nothing to do with the craftsmanship. Actually, I can't say that for certain on others, but I saw mine and it looked great before going in and it was balanced.
                      It really bothered me at first, but after a month or so it disappeared into the background. Plus the addition of a nice exhaust rumble helped too. I wasn't 100% convinced at first that it was flywheel clatter - I thought it was a dodgy clutch release bearing because it changed when depressing/lifting the clutch. Whilst my 'box was out recently the clutch release bearing was changed, so I'll finally know for sure soon. I'm also going to use Red Line Heavyweight Gear Oil (for a different reason) and maybe that will damp out some clatter.
                      David
                      '91 3B S2 Coupe
                      • Mark Halligan
                        • 2001
                        Linky
                        http://www.corner-carvers.com/forums/sh ... hp?t=31358 What he's talking about makes sense. I think I've 'heard' it before, even on my sprung-clutch, stock flywheel 80 (mostly when pulling away from really slow corners in second gear, below maybe even 1700rpm...sounds like a box of rocks)...
                        Any idea on what that concoction of oil was that the M3 owners were using?
                        Mark - Modded
                        • Mark Halligan
                          • 2001
                          Just been googling up some info on that oil blend and found another link explaining the rattle....
                          Mark - Modded
                          • DJones
                            • Jun 2005
                            • 2020
                            http://www.uucmotorwerks.com/flywheel/gear_rattle.htm
                            Interesting read.. I have an exceptionally light 3B flywheel with a six paddle sprung driven plate and must admit i have not heard the rattle.
                            • topsparky
                              • Oct 2005
                              • 2014
                              probably because it's drowned out by your wife's
                              screaming
                              1. SHORT SHIFT KIT
                              2. PORSCHE CAYENNE CALIPERS
                              3. H & R SPRINGS
                              4. BILSTEIN SHOXS
                              5. NEW BUSHES AND HP2 STRUTS
                              8. fmic fitted
