Which cylinder runs hottest?
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    Trying to determine where to mount a knock sensor for a stand alone knocklite.
    Any ideas as to which of the 5 cylinders that runs most hot (thus most likely to knock)?
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
  • iain1067
    • 984
    i think it's the rear one
    • A80Avant
      • 10873
      • Country: Greece
      my previous mechanic had told me that the cylinder on the 5cyl engine that gets more stress is the 3d,that is why there are usually cracks there
      • EspenW
        • Apr 2007
        • 1534
        • Country: Norway
        Hmm, from an air cooling perspective, the rear one will see the least airflow. However, the middle ones sit next to the turbo and the middle of the exhaust manifold.
        Knock Sensor I listens to cylinders 1-3, while Knock Sensor II listens to cylinders 4-5, so #1 takes input from the most. Will probably use that signal for the knocklite.
        1994 80E Avant
