Braided fuel lines
  • terrybullwon
    • Mar 2006
    • 8782
    Braided fuel lines
    Has any one looked into braided lines from the tank forward? I did not get the chance today to look under the car and refresh my memory of what is there but i did have a look in the family album.
    Now this has left me with a few questions.
    :End fittings to the Bosch FPR are M12 and M14?
    :Using a after market fuel filter or two?
    :The expansion chamber shown on the drawing, this is to stop fuel escaping when the tank in very full or on a hot day when the tank starts to expand with the heat?
    :3 lines on the system
    1.supply
    2.return
    3.breather to carbon canister?
    So in reality NO.3 could be exited from the rear of the car and be no real problem?
    Chef
    I wondered about this as mine are pretty rust and will need doing before too long, but never really got further than thinking about it lol.
    • BRY
      • 3755
      Unless your sat at the lights on a hot day and somone throws a fag on the floor.
      • s2driveruk
        • 12696
        brings a whole new meaning to an explosive get away from the lights
        1992 3b S2 Coupe
        • S2_Dave
          • Aug 2005
          • 456
          Is there the makings of a group buy here to bring the cost down? Particularly if they'd need to be made up. I'd definitely be interested ! I don't fancy routing the breather to the rear though .
          David
          '91 3B S2 Coupe
          • terrybullwon
            • Mar 2006
            • 8782
            I will have a price before supper, I will PM it to you doubt its going to be cheap
            Chef
            • volcano rs
              • Jun 2005
              • 2265
              1.supply
              2.return
              i've already got braided fuel lines from front to back on my shorty .like you said not cheap but easy to route because of flex
              • terrybullwon
                • Mar 2006
                • 8782
                Jamil,
                What -AN did you -8 or -6?
                Chef
                • S2_Dave
                  • Aug 2005
                  • 456
                  Ta.
                  They rarely are for these cars .
                  David
                  '91 3B S2 Coupe
                  • volcano rs
                    • Jun 2005
                    • 2265
                    Jamil,
                    can't remember now .the bigger the better
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Had phone call from the company they would be happy to do a discount for a group buy
                      I have to send all my old lines off to them for fitting
                      Chef
                        Good work James
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Oh ****
                          Well i took mine of today so that i could take the fittings off and make a mock braied set up.
                          Well what a shock
                          There were two leaks one towards the gear box tunnel and one before the fuel filter. Also the union connections at the fuel tank were pretty tatty to.. This is only came visable when i slacked off the brackets that hold the rails to the car
                          Look away if you must
                          Chef
                          • Acidburn
                            • 13459
                            Not to bad
                            Tempted to change to these, even tho I have had the lines changed on mine.
                            • S-Express
                              • Nov 2006
                              • 1133
                              I did a how too a few months back for replacing fuel lines:
