Is the RS2 ECU harness one section or two?
  • PeterS
    • 423
    Gents (and ladies)
    Is the RS2 ECU harness a "one section" harness, similar to the AAN harness or the 200 3B harness, or is it like the S2-3B one, which is two pieces and has a connector at the firewall?
    Actually, same question for the ABY...is it a one or two section harness?
    Looking at possible options when converting my USA spec Coupe Quattro to an ersatz S2...
    Thanks!
    -Peter
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
    Its connectorized as 2 pieces for sure - well more actually as you have those lil sub looms for coilpacks, knock and such... But the main interface point with vehicle loom is those two 8 pin connectors at the firewall/bulkhead.
    I have a spare ABY loom here which I have checked and labelled if that helps you. Its the same as RS2 - give or take maybe the odd wire colour.
    Paul
    • PeterS
      • 423
      Thanks Paul!
      Any chance that you could post a picture?
      -Peter
      Peter S
      1991 Coupe Quattro
      1991 Coupe Quattro
      1995 S6 Sedan
      1995 S6 Wagon
        Sure - later though - its in the garage loft somewhere
