First of all I'm glad you're around everytime I have trouble with my S2.
Got quite a lot of help on this forum in the past.
And I will tell you the long story of my two stolen S2, if you are interested?
But now to the point. I did the head gasket by myself, the first time at all.
I was a proud I had the engine parts together again, but I made at least four mistakes:
1 I did not drain the water out of the block at first
2 I did not drain the oil (mistake?)
3 Too proud I ignored the way too high oil level
4 I started the engine
The engine started at once, revved smoothly on idle, and then stalled, along with my heart.
I drained the oil/water stuff out and filled new oil in.
I revved the engine with the starter and without ignition a while
Again, I drained the oil/water stuff out and filled new oil.
as the oil level went lower, i filled up to the upper mark.
and with a constant oil level, I gave it a new start - 3 seconds idle, and then it stalled again.
I compared the new oil with the stuff that is in now, I can't see/feel any difference.
So I believe the oil is more or less ok now.
The blink codes give me a 4-4-4-4, no electrical faults so far.
As I didn't touch the fuel lines I don't expect a fault there (btw the pump is somewhat new).
I did the ecu power on self test, everything clicked nicely.
What do you think? Am I on the right way now?
Or has the engine to be disassembled to bits?
Do you think the lubrication is ok now and I do not have to expect any (further) damage of the engine? What should I do next? I would go to church if that helps??
Any hints?
Stephan
P.S. its a '93 ABY Avant Panthero black
What do you think? Am I on the right way now?Or has the engine to be disassembled to bits?
Any hints?
Stephan
