Hi All
With any luck i'll begin re-building my engine in the next month or so and only have a handfull of items left to organise. One of those is the Turbo/Manifold support bracket. As i've not undertaken this task before i'm looking for any pointers on how best to go about it? I've been trawling through previous threads and looking at engine bay photos etc checking where the supports are mounted on the cam cover but it's the connection to the turbo and any support beneath it that i'm not sure about?? Is there a connection to the engine mount point required? There also seems to be all manner of designs about with quite a few of you using a rose jointed system and others just going for a straight welded frame support. Is there a prefered method or does it not matter so long as there's support? Additionaly i'll need someone to make this support
and wondered if anyone knows of an engineer near or in bristol that could undertake this task for me?
Any advice you can offer will be much appreciated.
Russ
and wondered if anyone knows of an engineer near or in bristol that could undertake this task for me?Any advice you can offer will be much appreciated.
Russ
