which oil to 7A engine
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    which oil do you use in your 7A engine? thanks
    Audi Coupe Quattro 2.3 20V
    5w40 synthetic for me
    • iain1067
      • 984
      too thin imo, 10/40
      • Flat on my back
        • Jan 2007
        • 2449
        This one...
        Fuchs Supersyn 5w-40, and damn cheap at GSF!!!
        as recommended by OPIE oils.
        Carlos.
        • 20Vcqdriver
          • 829
          oil
          Castrol magnatec 10w/40 and occasional addition of slick 50. Always ran well with it.
          1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
          2004 A4 2.5TDi convertible, re-mapped to 180bhp
          2011 A5 sportback 3TDi-Backbox delete, remap
          • Acidburn
            • 13459
            I'd also agree with the 10w 40 tbh think 5 is a bit thin.
            • caliper
              • Sep 2007
              • 8
              I've used castrol 5w-40, very bad. then i tried castrol rs 0w-40, much better, today i changed it shell 5w-40, don't know yet.
              • Tom_
                • Oct 2007
                • 1301
                caliper : so some new experience with shell 5W-40 ?
                  5W-40 is best in winter and if you use the car on relatively short journeys (>15 mins) becasue it is less viscous it will provide better protection from cold and under cooler running conditions. 10W-40 will be fine in the summer or if using for longer journeys.
                  Far more important is the quality of the oil used IMO
                  • Tom_
                    • Oct 2007
                    • 1301
                    and which brand oil do you use?
                    • Tom_
                      • Oct 2007
                      • 1301
                      and what do you say on 5W-50?
                      • Tom_
                        • Oct 2007
                        • 1301
                        some more experience?i will be pleased for each one ...
                        • dubmeister
                          • 522
                          Viscosity depends a lot on the mileage of the vehicle- 5w50 too thin for anything over 100k, 10w50 better bet. IMO
                          But as said previously, quality oil is far more important (fuchs/mobil/castrol) and before every oil change use a flush and
                          OE filter.
                          e.g.-http://cgi.ebay.co.uk/WYNNS-ENGINE-O...QQcmdZViewItem
                          cleans all the old **** out!!!
                            5w40 for me as I do short journeys and crawls sometimes.
                            Next would be 10w50
                            Haven't found a single good 10w40
                            There is no correct oil just the one that suits your driving best.
