90q 7a engine prob??
  • adamw
    • Dec 2005
    • 348
    • Country: Shetland Islands
    hi i hope someone could shed some light on this...
    i spoke to a guy that has a H reg 90q with a problem regarding the distributor.
    the plastic dizzy gear broke so he towed it to his house and put a new one on but it wouldnt start??
    he put a new bosch dizzy on and still nothing... the codes have been pulled and all it comes up is the timeing is out so he got that checked and it aint that... there is power going to the dizzy but he said nothing is comeing out to the plugs??
    i asked him if the leads were ok... he said thay should be, it was running fine until he changed the dizzy then nothing??
    is there any common problems with the 7a engines?
    is there any way to change the dizzy to coil packs or something similar?
    addvice much appreciated
    cheers adam
    cheeRS adam
    RS2+
  • 20Vcqdriver
    • 829
    disi
    You need to be pretty accurate when setting up the distributer. Setting up TDC using the flywheel mark and double checking by removing No1 spark plug and placing a straw or similar in to sit on the piston. Once you have TDC insert the distributer so that with it inserted the centre of the rotor is dead centre with the notch on the housing. Assuming the disi plug and cable were not damaged and and on turning the crank by hand one revolution the distributor can be seen to turn too, it should start. If not it will require some more in depth testing. Good luck.
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
    • Acidburn
      • 13459
      If you do a search for robotron there is a thread he started with this problem and I uploaded pictures of the timing marks to his thread
      • 20Vcqdriver
        • 829
        addition
        Forgot to add that the cams have to be in the right position too. The 2 dots have to perfectly aligned with the face of the head (both valves shut) as well as the piston at TDC. only then set up distributer as per original post.
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          If he hasn't touched anything else, then either the distrubutor isn't positioned correctly, or the hall sender isn't plugged in.
          Check here for all timing marks. As said, all the marks have to be spot on.
          The cams should still be timed correctly, unless he has removed them.
          SS
          • adamw
            • Dec 2005
            • 348
            apart from the timing would there be any other reason why she wont start? (just to make shure nothing else is stoping it)
            cheers adam
            cheeRS adam
            RS2+
            • Flat on my back
              • Jan 2007
              • 2449
              If the TDC reference pin on the flywheel has dropped off, it wont start either.
              Carlos.
              • adamw
                • Dec 2005
                • 348
                the pin is supposidly there....
                cheeRS adam
                RS2+
