Just to get it straight in my head, what controls the amount a fuel injected into the car? My current knowledge is as below, if there is anything wrong or missing, please tell me.
1. At WOT, the fueling is controlled purely by readings taken from the MAF. The ECU recieves readings about the Air Mass passing the MAF and adjusts fuelong appropriately to a set Air Fuel Ratio (% of fuel to air).
2. At other times, the AFR is measured by MAF as per No. 1 but the Lambda Sensor is used for fine adjustments.
Am I right?
Am I right?
