JE Pistons Question
  • mocas
    • Jan 2007
    • 49
    • Home: Madeira Current: Canada
    JE Pistons Question
    I know the vw 16v block has the same height and bore of the audi 2.2l i just got my pistons today and on the box it says vw 16v 9A is this Common? I did get 5 pistons and rings etc. Anyone else get their pistons from Je and get that on the box ?
    There are two choices in life-Take it or leave it !
  • volcano rs
    • Jun 2005
    • 2265
    possibly the same i know the rods are the same
    • mocas
      • Jan 2007
      • 49
      Thats what they look like.
      Specs are:
      Bore:3.248 Dish.070
      Comp Height 1.290 Top Ring 1.0mm
      Forging 81MD4 2nd Ring 1.2mm
      Pin Dia .787 Oil Ring 2.8mm
      Pin Length 2.250 Actual Weight 296
      JE .50 Wire Locks
      • kwlw
        • Sep 2004
        • 1025
        • Country: Lithuania
        I know, that VW guys are using S2 pistons in some turbo VW's. If I remember correctly - in KR and PL engines. Assuming, that 9A has same block (not sure about it) as those mentioned before - they may work, and be same item.
        Sau
        • GazzaG60
          • 4133
          the 9a is a bigger bore. 82.5 IIRC. its a different block.
          the oil squirter is on the oposite side in a VW meaning the pistons are machined different.
          never been sure why people use s2 pistons as the standard ones are good for 400WHP+
          KR ands PL are the small bore units. they dont take a 83mm too well as it interferes with the squirter. 9a will take 84mm no worries.
          9a is same as audi 6a. it has a bubbled out lower block to clear the crank difference.
          • mocas
            • Jan 2007
            • 49
            Contacted the person i got them from this is what i got.
            no mistake, its a custom order, and thats how JE Pistons lable it. 100 % GOOD TO GO
            Guess I will have to wait and see
              Bore:3.248 = 82.5 mm
              They are a custom order as it looks like they have contact reduction grooves at the top of the piston.
              • mocas
                • Jan 2007
                • 49
                Yes jamo thats what the guy i bought if from said and it says Custom on the sticker too? They are supposed to be RS2 Spec Forged Pistons 82.5mm Bore.
