Vasilis
Accumulator grooves shouldn't increase bore wear. They are basically a groove machined into the ringland between the top and second rings.
The idea of this groove is to act as a 'reservoir' for any gases that leak past the top ring and get stopped/slowed down at the second ring.
A build up of these combustion gasses can cause the top ring to flutter at high rpm and lose even more seal.
The only obvious possible downside (I can think of) is that because material is removed from the middle ringland this could compromise its strength and cause it to collapse in extreme stress conditions. But that would be extreme, just watch your ring gaps....
I set my JE's to 0.004" (0.10mm) and I get light slapping when the motor is cold, Darius is probably right if you are not going to run big boost and want longevity along with tighter tolerances and quieter running go for the 4032 alloy pistons.
have the outcut for oilsquirters in the pistonscurt..... the piston WILL crack there, and the crack will go to the oilringgroove or to the xpin hole( spec for the 3.rd syl.... even on a std engine)
