Brought one of these kits from Correy about 9 months ago.
Had problems with a broken pin just before Christmas which Correy replaced no problem, I put it down to one of those things.
On Friday car developed a miss fire under load, got her in the garage and had a play.
Found another broken pin and a burnt out pin
also the connectors appear oxidised.
Contacted Correy and Javid at 034. It appears there was an error in manufacturing on the early harnesses that slipped the net.
Correy was unaware of this and will be contacting all those with these kits to make sure harnesses are checked/replaced.
Correy and Javid have been bang on sorting this out both returning speedy responses to emails and offering to replace the coils and harness.
I still stand by this kit and would recommend it as before these problems started it performed better than the standard set up.
Many thanks to Javid and Correy for sorting this so quickly
also the connectors appear oxidised.Contacted Correy and Javid at 034. It appears there was an error in manufacturing on the early harnesses that slipped the net.
