which maf? sport quattro or bmw m5?
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    which maf would you use for 500 + hp 2.2 liter 20V?
    sport quattro ,bmw m5 or any other
    Quattro
  • Mihnea
    • 1288
    BMW M5 works ok with the appropriate software/hardware tweaks and with the right pinout on the connector (round)
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • timucin
      • Nov 2003
      • 869
      • Country: Turkey
      do you have the part number?shall i order now? or we leave it to the end?
      Quattro
      • Sweeper
        • 1317
        • Country: Latvia
        timucin: Did you rob the bank ?
        Vadim.
        New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
        • timucin
          • Nov 2003
          • 869
          • Country: Turkey
          LOL, i wish i did...
          Quattro
          • OZzzt
            • 43
            Much cheaper to rip your old one out of it's casing and put in a piece of 4" tube...
            • Mihnea
              • 1288
              The end result is still the same, the car still won't run because of hardware/software incompatibilities....
              www.MRCTuning.com
              info@MRCTuning.com
              Workshop Directions
              • Dutch_RsBlueS2
                • Sep 2003
                • 285
                Yes but you mean it won`t be able to run at all by putting your als sensor in a new peace of 4" tube ? Also not when you`re remapped it ?
                Cees
                • Mihnea
                  • 1288
                  Cees
                  Of course it will run after I've remapped it, but the 4" tube isn't a good idea because this means each car has to have each fuel and ignition advance cell in the maps mapped specifically at all load/RPM points, which is only possible on a brake dyno...
                  The M5 solution is a lot better, as this type of MAF is known and one can easily spot the right value for the resistor that has to be changed in the ECU, as well as correct all the maps properly too...
                  HTH,
                  Mihnea
                  www.MRCTuning.com
                  info@MRCTuning.com
                  Workshop Directions
                  • timucin
                    • Nov 2003
                    • 869
                    • Country: Turkey
                    Mihnea;
                    do you have the part number of bmw part?
                    cause i am sure we cant find it on the shelf here, i have to order, or may be can you bring it in your bag while you are coming?
                    Quattro
                    • quattro4Life
                      • 92
                      which generation M5 is this taken from? how does it compare to the porsche 928 MAF that others have used?
                      -b
                      Im not the percent you think survives,
                      I need sanctuary in the pages of this book...
                      • Dutch_RsBlueS2
                        • Sep 2003
                        • 285
                        What does such an m5 MAF cost ?
                        Cheers Cees
                        • audiman
                          • 4827
                          The M5 and the SQ MAF's are the same.
                          Also same as Porsche 928S
                          I looked all this up on another thread.
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • Dutch_RsBlueS2
                            • Sep 2003
                            • 285
                            the dad of a friend of me has got an m5 :nana:
                            Got to visit them with my toolbox
                            Does anybody knows a certain price for a m5 MAF?
                            Cees
                            • Stick Insect
                              • Dec 2003
                              • 2338
                              Cees,
                              call your local BMW dealer. It is the easiest way.
                              David
