I'll start to apologize from the beginning for my poor english.
Car: audi s2-91 3b ECU
The car has not been driven(just started and driven around the block) since summer 2006 due to finacial situation, and when it was put away it worked just fine.
Then last spring (2007) i was going to start it up but i only had a poorly charged battery(almost dead), well i tried anyway but when i turned the key nothing happened except there was a strange sound from the ecu, it sounded almost like a machine gun and i heard it very well cause the starter engine wasn't even turning.
So after a couple of tries i gave up and about 1-2 months later i bought a new battery and then it started at the first try. Well, i drove the car out of the garage and had it ideling for 5-10 minutes, then when i was going to rev it a bit i noticed the rpm meter was dead, it doesn't move at all, the needle is stuck at 0 rpm constantly.
And when i drive the car at full trottle for more than approx 2 seconds i get the "forehead through the windsheild" effect and then i have to restart the car to be able to get another 2 seconds of action before it cuts off again.
So what's happened ? i've heard that the ECU is pretty sensitive to voltage peaks so maybe i've broken/fried it ? Does anyone else have any experience of this problem ?
The car and everything in it works just fine as it has done before except from the dead rpm-meter and the cut-offs, and it works fine to drive around if your easy on the gaspedal, but thats just booring
Hoping for a solution.
Best Regards // Johan
). It happens sometimes, that tachometer (usually dashboard metal on plastic "wires") fail. Your car was standing for a long time as far I understand. Cars not used sometimes develop strange electrical "gremlins", which are real PITA to find and fix.
