test drove.. and got some problem
  • zlobo
    • 967
    I test drov my car today.. (have not driven it since oct) every thing vas ok until a fuelline broke down.. the car started to act stange. and whwn i felt the smel of fuel i stoped. i noticed that fuel line to the fuel rail was leaking.
    (it was spraying fuel all over the engine) i fixed this leak.. and now i got a problem that the engine started to misfirering when i try to rew up the engin fast.. but when i do it slow its no problem. does anyone have a clu what it can be?
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
  • Stick Insect
    • Dec 2003
    • 2338
    Zlobo, I don't know if you have coil packs or a distributer. The fuel may have got in your dizzy and is causing a misfire.
    If you have not driven the car since October and done lots of work it may be something else and not the fuel spray.
    David
    • zlobo
      • 967
      i have a distributer, but the funy is that befor the fuel line broke down. i did't have the misfire. i drove the car for about 5min before the fuel line broke,
      kostic.nu
      • quattro4Life
        • 92
        i think what he is saying is that as a result of your broken fuel line spraying fuel over your engine compartment, it may have gotten into a crack in your dizzy, or maybe in your plug lines.
        -b
        Im not the percent you think survives,
        I need sanctuary in the pages of this book...
        • Stick Insect
          • Dec 2003
          • 2338
          The misfirng problem may not be anything to do with the fuel leak.
          It could be something else.
          Is there a fuel pressure sensor which is getting a bad signal?
          Can you pull the error codes from the ECU?
          HTH
          David
          • zlobo
            • 967
            I am gonig to check for erorcodes in the morning.
            kostic.nu
            • zlobo
              • 967
              checked for errors today in the ecu.. sems that the maf is dead.. ..
              kostic.nu
