question : K26/GT3071 Dual BB Turbocharger
  • Keith
    • Sep 2003
    • 84
    • Country: France
    Hello to all.
    I'd like to have your opinion about this turbo.
    I'm planning to change my RS2 K24/7200 on my ABY (RS2 modified) to this Garett GT3071.
    If you have a feeling about this one :
    Here are my mods :
    RS2 inj.
    RS2 Exhaust/inlet manifolds
    7A exhaust cam
    RS2 Intercooler
    Chiptunned
    my exhaust seems to be a little restrictive so I won't be able go over 380HP anyway.
    I'd like to have boost a little earlier than the RS2 K24/7200 (full boost @4000 rpm 1.8/1.9 bar - boost @7000rpm around 1.4bar)
    - behaviour @ low revs
    - behaviour @ high revs
    - Installation (does it mounts without mods ?)
    If anyone have tried, I'm interested !
    Keith
  • NoNonsense
    Forum Sponsor
    • Apr 2004
    • 673
    The GT3071R is a fantastic turbo that will have a matched boost threshold to your existing turbo. If you want a lower boost threshold, look to the GT2871R. It will give you about 420 crank hp but spool up quicker than the RS2 K24.
    Joe "NoNonsense"
    axis motorsport
    joe@axismotorsport.com
    • Puglife
      • Jun 2006
      • 731
      Whats the GT3071R rated to? about 500bhp?
      Jay - pug_life85@hotmail.com
      1986 Audi UR quattro - WORK IN PROGRESS
      1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
      • Billman
        • 4129
        i would say rather 460 bhp. Ot has a rather small 53mm compressor inducer diameter.
        See also the thread from PapVas (450 RS2) about his experience with the GT3071.
        Go Holset or Go RS4
          450 if mapped very aggressively but more likely 430bhp
          • mastermind
            • Jan 2005
            • 244
            • Country: South Africa
            You will need bigger injectors, Javed of 034 does an injector and generic chip upgrade for this turbo on an RS2 Spec.
            The Red Baron
            (R)S2 spec, 034 GT3071
            Wagner Short Intake and Intercooler
            Whiteline, Custom Shocks with external reservoirs
            8pot calipers with A8 discs
            Vems
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              want a laugh? i just made 358hp crank supposedly on a maha dyno at 1.65bar on the 3071R turbo.....which i think is way out of proportion since i also have 56Nm of torgue!!!!!
              i think it is impossible!!!
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Didn't Ross's old Coupé make ~430 bhp with higher than stock CR and the 0.63 hotside?
                That would suggest that even with the smallest hotside it's possible to make more than that with a lower CR and more aggressive timing.
                SS
                • K7ERG
                  • 1711
                  I have the GT3071R with 0.63 KKK26 fitment
                  I have 8:5.1 CR
                  7A exhaust cam
                  Tubular exhaust manifold
                  55lb injectors
                  Huge interooler
                  3" downpipe/system
                  And going Vems management
                  Anyone want to guess a power figure for my spec............. Hopefully run at least 2BAR.
                  Craig
                  Audi A6 AEL 5cyl Quattro breaking.
                  Audi A5 3.0tdi Quattro Stage 2
                  07947385043
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    ross also had the 7A exhaust cam
                      That's what I said more aggressive mapping
                      Remember Ross was at 2.0 - 2.1 bar which is on the edge of the garrett map.
                      • Keith
                        • Sep 2003
                        • 84
                        • Country: France
                        I have 8:5.1 CR
                        7A exhaust cam
                        55lb injectors
                        Huge interooler
                        3" downpipe/system
                        Craig
                        420 HP ????
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          55lbs are too good for this turbo.I use the 52lbs (green tops) which are big and thankfully give me no cold start problems.
                          If you run a steady boost @ 2bar then you will easily get more than 400hp crank.The tubular EM also helps in the boost area and the ability to have low EGTs,but the .63A/R is a tough compromise.
                          If i were to choose all over again,i would sacrifice 500rpm to get an easy 450hp with a GT30R turbo
                          • K7ERG
                            • 1711
                            I have a 034 adjustable fuel regulator so shouldnt be a problem. If i can run more boost than 2 bar i will if it makes the 450bhp. See what happens once mapped. The joys of having a good mapper as a mate and a rolling road
                            07947385043
                            • EspenW
                              • Apr 2007
                              • 1534
                              • Country: Norway
                              That is ridiculous, on a MAHA, that probably means you pulled less than 200hp at the wheels?
                              1994 80E Avant
                              1986 2L Golf 2 on Alcohol
