Starter Motor (again)
  • Greenm3
    • Jul 2004
    • 512
    Before i go and buy a new starter, is there any simple reson why it just wont kick in, the engine is just nearing compleation and need to test it, will it make a difference if the earths arent conected on the IM?
    I just want to make doubly sure its not me and my wiring, does the ECU have anything to the starter either? Thanks Michael
  • Al Wyn
    • Nov 2006
    • 3746
    Are you 100% sure your battery is good and fully charged?
    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
    • Greenm3
      • Jul 2004
      • 512
      It was good holding Charge, but yes might just try a different battery not that i dont trust myself but "just in case".
      I had all the dash lights and that but there was ntohing at all when i turned the key, also i put 12v across the starter and nothing happened. Does that mean it dead?
      Michael
      • Al Wyn
        • Nov 2006
        • 3746
        Mike iirc hasnt your S2 been off the road for quite a while? Go straight for the other good battery before paying out for the starter... other thing to have a quick gander at is ingition switch behind key try wiggling (tech jargon ) it a bit and check the connections at the back... connections on the starter???
          What you mean you put 12V across the starter ?
          There is always 12V connected to the big bad starter terminal (and ground via body) - the starter is only energised when 12V is applied to the solenoid device attached to the starter body - thats the signal what comes from the key.
          You MUST have all the engine earths attached for the thing to have any real chance of firing into life.
          Paul
          • mcandmar
            • Apr 2004
            • 5118
            Make sure the main earth cable is attached, without it your going to pull all the current through all the other electrical connections and cause a melt down. You can use a jumper lead to short the main + power and the solenoid to test the unit, just in case the faults with your ignition switch or wiring. Just make sure the car is NOT in gear when you test it!
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • Greenm3
              • Jul 2004
              • 512
              With main earth attached i put 12v across the solinoid, and nothing, so i assume it is finished! Will wire up everything properly and try the new battery.
              Thanks for the help though i'm sliding towards a new starter!
              Michael
              • mcandmar
                • Apr 2004
                • 5118
                Have you tried giving it a smack with a hammer? Seriously i have had starters seize up after sitting for a while.
                • Greenm3
                  • Jul 2004
                  • 512
                  Yea first thing i tried, cuase i know the pin sometimes sticks when not been used for a while. I ve got a new one now anyway, pretty much everythign else under the boonet is new, so might as well go with the a new starter!
                  Thanks for the Help, we shall see tommrow if it actually is the starter!
                  Michael
                  • caterpillar
                    • 2480
                    its the same starter in ALL 5 syl( exept eurovan)
                    have you the battery in the coupe or?? if so the battery cable may gone bad, or the ingnition SWITCH behind the steering lock are gone( most commen)..... both big ( 20mm2)conecktions are + on the starter.....
