engine/gearbox mounts...help
  • andyg plym
    • Nov 2006
    • 4646
    my avant is making some funny noises at the moment,usually when you lift of the throttle. it tends to squeek,sounds like the prop rubbing on summat (heatshield?),and is quite jerky.
    recently i suspected the engine mounts to be ******ed as i managed to rock the engine side to side by man handling it.
    question is apart from snub mount are there just 2 other engine mounts,and also how many gearbox mounts are under there?
    6 speed ABY
    cheers beys
  • s2driveruk
    • 12696
    1xsnub, 2x engine mounts, 2x gearbox mounts, 1x centre mount for prop and 3x diffmounts
    1992 3b S2 Coupe
    • andyg plym
      • Nov 2006
      • 4646
      doh
      lookes like its gunna be expensive,anywhere cheaper then vagparts?
      • s2driveruk
        • 12696
        engine mounts are about £50ea and the others about £15 each except for rear diff mount with alloy casting which is about £60 IIRC
        would expect vagparts to be the cheapest
        1992 3b S2 Coupe
        • MarkT
          • Apr 2006
          • 82
          I purchased engine and gearbox mounts from Pete Reeves @ quattrocorner for my ur., he may be able to help you
          Cheers Mark
