kkk26/27 max output
  • Bambi
    • Oct 2005
    • 41
    • Country: South Africa
    kkk26/27 max output
    Does anyone know what the max boost profile is that I should run / expect to run on a kkk26/27 turbo. I'm currently getting 1.8 @ 4000 rpm which then quickly drops off to 1.4 @ 5000 and down to 1.2 @ 7000. I expected more but do not know how hard to push the boost on this turbo before it really becomes inefficient. Also stiull running original wastegate spring @ 0.5 bar.; shoul I increase this to 0.8 bar?
    I dont have the cash now, but would like to start thinking in the direction of a new turbo. What do you think of GT30-71. I want as much power as possible. I fitted SPM conrods, gasflowed the head and installed 7A exhaust CAM. Is 1.8 bar all the way too much? I prefer a setup that would work on the track.
    Speaking of track - where can I get a good suspension setup? Is Eibach the one to have?
    1993 URS4 530hp Twincharged
    2002 S8
    It depends on the hotside of the K26/K27
    Your boost profile is the same as my K26/K27
    I would say your touching 380bhp at 1.8 bar
    You won't see it hold boost on an ABY as 1.8 is overboost and then it drops the level AFAIK
