Changing The Mfts, Do You Drain All Collant Or Not
  • 220bhp
    • 2578
    • Home: United Kingdom
    To change the mfts and the temperature sensor in the back of the head is it necessary to drain all the coolant.
  • PeteRR
    • 1326
    Not if you're quick enough swapping them over. You'll loose a small amount of coolant but not much.
      First of all you need a 29 mm deep socket. It has to be deep so the switch part fits into the socket far enough so the socket can contact the hex part of the MFTS. Doing the swap is pretty easy and does not necessarily mean draining anything.
      If you are good, you can do it with out draining the rad and still only lose about 200 mL(or less) of coolant. I changed mine on my AAN in my Sunday clothes while waiting for my wife to come out of the house to go for Sunday brunch. I was just trialling it to see how I would do it when we came back home and before you know it (about 5 minutes), I had removed the old one and replaced it with the new one. There was some tricky finger work while doing the Dutch-boy dike plugging thing with one finger and handing-off the old one from my right hand to my left hand and then feeding the new one from the left hand to my right hand and then starting the threads by hand. NOTE: All this was done with the engine just warm from getting out of the garage to the street. DON'T DO IT with the engine HOT!!
      HTH
      • 220bhp
        • 2578
        Chears,all done ,no prob's
        • andyg plym
          • Nov 2006
          • 4646
          where did you get the mfts and how much?
          cheers
          andy
          • QuattroFever
            • May 2006
            • 1360
            sorry, but what is an MFTS?? Fan Switch?
            Volcano ABY coupe
            Ant
            • topsparky
              • Oct 2005
              • 2014
              multi function temperature switch
              is how the ecu sees how hot or cold the engine is
              1. SHORT SHIFT KIT
              2. PORSCHE CAYENNE CALIPERS
              3. H & R SPRINGS
              4. BILSTEIN SHOXS
              5. NEW BUSHES AND HP2 STRUTS
              8. fmic fitted
              • QuattroFever
                • May 2006
                • 1360
                cheers dude
                Volcano ABY coupe
                Ant
                • dest
                  • 4287
                  I need to do mine soon, do you have to remove anything to get access?
                  • GT500
                    • Jun 2006
                    • 2181
                    Nothing to move, just when you release the plug connector they usualy fall apart! hot and cold 10.000 times and it all gets a bit brittle.
                    Get a plug from the stealers at the same as ordering mfts, GSF ones are faulty out of the box!
                    HTH
                    Rob..
                    87 UR 20v ABY
                    97 S6 Avant
                    • s2_southwest
                      • Oct 2004
                      • 823
                      Does this sensor drive the temp gauge on the dash? My temp gauge doesnt work anymore, ive replaced the 2 sensors on the water manifold and had the one on the main rad changed a while ago, i guess that leaves the mfts sensor at the back of the head
                      Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
                      • LHD_Kid
                        • May 2006
                        • 3697
                        The small one on the back of the engine is only used by the ECU (by the bulkhead) the larger of the 2 in the water manifold is the MFTS, which is the one that drives the guage....
                        Chris
                          Chris
                          That is true for the AAN, ABY and ADU but the 3B uses the MFTS for the ECU coolant temp signal. See the link below for a better explanation and reference link:
                          http://forums.audiworld.com/s4s6/msgs/148742.phtml
                          HTH
                          • LHD_Kid
                            • May 2006
                            • 3697
                            This is quite interesting...... why is it then, that the small one by the bulkhead is connected to the ECU? (1991 3B) surely it would be obselete if the MFTS is used by the ECU?
                            I know mine is connected, as I had troubles with cold starting.....
                            Might have to delve deeper into this one....
                            I suspect on the 3B it uses both, but the point was that the MTFS drives the guage, not the smaller one. (Incidentally the posters referring, both have ABY's)
                            Chris
                            • Condor
                              • Jul 2004
                              • 424
                              mfts
                              Hi, I'm going to be replacing the mfts on my 3b as have temp gauge symptoms (reading low) I think engine maybe over fueling too and now taking slightly longer to start from cold, my question is does the sensor need a washer when being replaced? is anything required on the threads when installing a new mfts ie ptfe tape/joint paste?
                              Thanks....
                              :wave: :thumbs:
