Non Starter, story so far.....
  • Greenm3
    • Jul 2004
    • 512
    After the rebuild and the starter motor being a no go, replaced that and removed the immobilser, but i'm still getting no sprak or fuel. Could this be a relay? or ECU? I'ma stuck now really dont know where to go? any BTDT's?
    CHeers Mike
    Checked all the fuses for the ECU - S2central lists them for 3B and ABY...
    Only relay to worry about is fuel pump relay - you can bridge round that if you like - SJMautotechnik shows that - but that doesn't explain no spark.
    Put an LED tester on the output of the hall sender - you should see a pulse cycle on #1...
