S2 flow rate in CFM
  • 20Vcqdriver
    • 829
    S2 flow rate in CFM
    Does anyone know what a standard S2 air flow rate is in CFM and how much it is with Homefries installed. Trying to correctly size up the charge cooler etc I need. thanks
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
    Do a search here for Turbology and my spreadsheet thang - its on S2central.net as well - send me a PM if you can't find it. There is some useful estimations on VE and such in there, but without flowbench figures and thermal analysis of air temps in and out of the IC then its darn hard to quantify their efficiency.
    An RS2 intercooler has been used up into 450bhp territory. I wouldn't want to push an ABY or 3B one past 350bhp but thats just gut feel really.
    Consider water injection also if air temps concern you on a big power motor - that has been proven to work on the 20VT engine. DJones runs it on his MD357 monster and I reckoned he is getting about 5% cooler air temps because of it - you'll find spreadsheets that model his setup if you look hard enough
    • Faheemo
      • Feb 2005
      • 544
      • Country: South Africa
      I've used the stock ABY inter cooler to 450hp region, but thats with a ball bearing turbo spinning within its efficiency. Water injection gave me about 7-10hp extra iirc and a temp drop of about 10 deg.
      check my project posts for details.
      S2 Coupe fully built.
      10.9 1/4mile 0-100 in 3.5secs
      Precision 6262 turbo
      The Green Monster
      • 20Vcqdriver
        • 829
        Info
        The turbology info very helpful. Now just need someone to tell me what pressure the 3B homefries run at. Thanks.
          1.4bar boost is as much as you reliably dare on K24... Dropping off to about 0.8bar on the redline - read the compressor map
          • Bram
            • Aug 2006
            • 2582
            I read somewhere on Motorgeek.com that the i5 engines can do around 200 CFM per cylinder.
              Its of that order in theory at least...
              If you do the math on a 2.5 stroker at 7000rpm (or 8000rpm on 2226cc) and 100% VE with 2bar boost (PR above ~3.3) you get into 1000cfm territory - which is 200 per cylinder. The trick is having an efficient trubo and intercooler running at those levels to keep air temps down for healthy combustion, knock avoidance and good mixture.
