Is that the Auto-pilot?
  • BlackBullet
    • 146
    • Country: Brazil
    In this foto anexed, this stick is from Auto-Pilot accelerate system?
    I was traveling when the auto-pilot has turned off whitout any command of mine!!!! And after that, the accelerator has blocked in maximos....
    A have pick it out of the engine....
    I´m correct???
    Reguards,
    Rafael Pinto
    Audi S2 1994/1995 Avant - Black
    Audi RS2 1994/1995 - Black
  • Lee
    • 1512
    Yes, the item you have arrowed is the actuator rod for the cruise control. The unit itself sits under the inlet manifod and attaches to the same point that the brown earth wires do via a bracket.
    Having this thing stick open sounds scary! Did you switch off the engine or did it recover itself? Or, was this your excuse to the police when they caught you speeding?!?! "I am sorry officer for driving so fast but my cruise control actuator jammed my throttle open!"
    HTH
    Lee
    Designun Limited....
    • Mark Halligan
      • 2001
      Yep thats the link arm for the cruise control.
      Cheers,
      Mark.
      Mark - Modded
      • BlackBullet
        • 146
        • Country: Brazil
        It will be a good excuse for the officer!
        So, when this stick jammed the throttle full opened, I have "kicked" the acceleretor pedal, almost 3 times, when it cames free. But, if it didn´t came free, I will turn the engine off!!!!
        So, now I need to make a new plastic from that stick, so than I can make my cruise control alive again!!!
        Reguards,
        Rafael Pinto
