Oil pressure relief valve...
  • Flat on my back
    • Jan 2007
    • 2449
    This is the last thing i need to remove from my block...
    Is it a special tool to remove this...looks like a long reach spline tool to me...any hints where i can get one?
    Thanks.
    Carlos.
  • terrybullwon
    • Mar 2006
    • 8782
    Thanks.
    Do you mean the oil check valve?
    Chef
    • terrybullwon
      • Mar 2006
      • 8782
      40 torxs :-)
      Chef
        This is the last thing i need to remove from my block... Is it a special tool to remove this...looks like a long reach spline tool to me...any hints where i can get one? Thanks.
        Isn't the oil pressure relief valve the tube with holes by the spring in this photo of an "exploded" oil pump?:
        • 220bhp
          • 2578
          • Home: United Kingdom
          Thats the little ****** that stuck open and cost me an engine.
          • terrybullwon
            • Mar 2006
            • 8782
            Are you not replacing your oil pump carl?
            Chef
            • Flat on my back
              • Jan 2007
              • 2449
              Ah...no...its
              that funny oil 'thingy' under one of the oil pressure sensors on the side of the block...defo a spline of some sort.
              Yep, will be replacing oil pump.
              Carlos.
              • terrybullwon
                • Mar 2006
                • 8782
                So it is the oil check valve, 17mm nut on the outer and then a 40T in side the block
                Chef
