miss fire under load
  • Polish
    • Feb 2008
    • 126
    might need help just been out in my s2 it has been stood for a week runs fine on tick over and revs out fine but when you put your foot down it miss fires and holds back ,but it does pull through it, any ideas or could it be just a bit of damp not had it for long so still finding out how tempermental they are
    Could be a bad plug, bad coil to boot connector (ABY) or coil (ABY). You might want to check this out:
    http://forums.audiworld.com/s4s6/msgs/149788.phtml
    • K Simmonds
      • Dec 2007
      • 7627
      If it's not the plug's then the MAF would be the next on my list.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
        Oops. Just checked your car specs. 3B, so the ABY-related issues won't help. Checking the plugs and distributor to plug wires should still be done. Speaking of distributor, what about the rotor. I believe there is an issue (potentially a nasty issue) if you run a 7A rotor instead of a proper 3B rotor. As I understand it, the 7A rotor has a wider contact than the 3B rotor and this can lead to "spark jump" (not good). You might want to check the part no.
        I think the 7A rotor is 055 905 225 B and the
        3B rotor is 052 905 225 C. Perhaps somebody could confirm that.
        Dave F.
        • K7ERG
          • 1711
          Type of plugs you are using?
          What is the plug gap?
          Worth changing the rotor arm (Right one as stated above) Distrubutor cap. after that look at replacing the leads.
          Bosch F5 DPOR plugs are great on these engines and are listed for the RS2.
          Audi A6 AEL 5cyl Quattro breaking.
          Audi A5 3.0tdi Quattro Stage 2
          07947385043
