Throttle Pot Resistance Output
  • Mark Halligan
    • 2001
    Hi
    My TPS is only showing 2430 ohms across pins 2 & 3 at the WOT position. I am pretty sure that I read somewhere it should be more than this, can anybody tell me if that is right?
    Oh, and no I am not getting enough boost, but strangely there is no TPS related fault code
    Does it sound like the TPS fooked?
    Mark - Modded
  • twoqu
    • Sep 2003
    • 3103
    There is a little info here!
    Will have to scroll down to the S4 one.
    • k.alle
      • Feb 2008
      • 801
      Originally posted by Mark Halligan
      Hi
      Well, all I an say is that my S2 only had 1800 Ohms at those pins, which were too little.
      Made a _world_ of difference changing the TPS, even though some say that they felt no difference changing the TPS.
      It is not cheep though
      Just my .02$
      Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
      http://www.garaget.org/?car=52877
      • Mark Halligan
        • 2001
        Thanks Robin
        I cut this tricky little fecker open and after stripping it down cleaned up the sliding contacts (tiny little brushes), there were no bad solder joints as described in that link.
        After I got it back together it gave me 2440 ohms as opposed to 2430 ohms so not a big difference there. Looks like I will probably need a new one?
        Mark - Modded
        • k.alle
          • Feb 2008
          • 801
          Well, don't give up just yet.
          Even though the Ohms seems low, the Voltage is the essential here.
          As I said, I had 1800 omhs at WOT but also had 4.5V at WOT which is too low.
          Check this URL for troubleshooting:
          • Mark Halligan
            • 2001
            http://www.s2central.net/ds_F60_G69.html
            Thanks I'll check the voltage next.
            Mark - Modded
