Hi guys any suggestions on the following?
I am just about to finish my project ( KKK26/27/29, MTM imo, etc).
I have moved the auxiliary "radiator" to the right so there is space for a filter between the headlamp and the auxiliary rad. which is ideal since it will get fesh air right from the mask. Will i have any problems if the RS2 MAF is 10cm away fro tme filter and 15cm away from the turbo? Note that i will use a matrix (vertical and horizontal pieces of metal in the adapter from Maf to Filter. Any ideas or BTDT welcome
