Inlet manifolds flow test
  • yodasfro
    replied
    That's interesting on the 3B vs. RS2 I thought the RS2 had a larger plenum? Well anyway I'm having a 3B hogged out for my 200 20v http://www.motorgeek.com/phpBB2/viewtopic.php?t=17525
  • Flat on my back
    replied
    AAN volume...
    measured at 3.05 litres...
    Question is...volume or flow, or both, which is best?
  • HPmuirt
    replied
    Originally posted by BRY
    Just to clarify:
    Stop waving at me and get your **** in the kitchen. The very fact that you have one for sale means that it is not attached to a car and therefore it should currently be full water in your kitchen....sheesh!
    Cheers n
    Si
  • BRY
    replied
    Just to clarify:
    Originally posted by HPmuirt
    does anyone have an RS2 IM for sale?
    Cheers n
    Si
  • Acidburn
    replied
    Well it would be good if we could get as much detail about each of the manifolds, what they hold, flow etc.
  • Flat on my back
    replied
    Eh...
    No one want to know the capacity of the AAN manny?
  • HPmuirt
    replied
    Well stop boasting and get in the kitchen then...Sheesh! (It's the room that your food magically appears from)
    Just plug up the holes in both manifolds with cellotape, fill the RS2 one with water, then carefull decant the water out of the RS2 into the ABY and measure how much water is left (if any) in your wifes measuring jug. Then get told off for playing with dirty car parts in the kitchen
    Once you have cleaned up the kitchen and made the wife a cuppa, you can go back to stripping eBay of any useful Audi parts
    Cheers n tears (of frustration)
    Si
    1...2...3.......duck
  • BRY
    replied
    If not, does anyone have an RS2 and S2 IM kicking around that they could fill with water to check the capacity?
    If there IS a difference, does anyone have an RS2 IM for sale?
    Cheers n
    Si
    Hi
    replied
    This is old new, http://www.s2forum.com/forum/showthread.php?t=15343
    I don't trust them flow figures as it's not done in a real world enviroment, plus flow is not everything, a high velocity is need to make torque.
  • Acidburn
    replied
    Originally Posted by bram
    Javad confirms that the RS2 IM has about 1 liter more volume.
    The 3B IM has a volume of 3.3 liters
    Interesting to know.
  • HPmuirt
    replied
    That is between a 3B and RS2. He makes no mention of the ABY. I always assumed that the ABY and RS2 were the same internally, anyone care to comment?
    Cheers n
    Si
  • Bram
    replied
    Here is Pisobiker confirming that the RS2 IM has a capacity of 4.2 liters (incl. runners).
    The 3B IM has a volume of 3.3 liters.
  • Bram
    replied
    I think you can still reach high HP numbers with a RS2 or 3B IM (good for at least 516 WHP), but it's just the unbalanced flow over the 5 cylinders that I would like to prevent.
    What I mean with this is that actually each cylinder has got to be tuned with a different AFR, while now you tune the whole engine on average AFR over the 5 cylinders, meaning some cylinders run a little richer or leaner. I guess you will get most performance an a equally flowed IM.
  • HPmuirt
    replied
    Originally posted by Acidburn
    I'd be interested to know this as like I said above i'm trying to decide what to fit to mine as the rs2 has to be modded to fit the 3b as newsh found out.
    Does that mean you have an RS2 IM that you might not fit as it is no better than the 3B one? Wanna swap it for a VDO boost gauge? :mischeif:
    Cheers n
    Si
  • Bram
    replied
    ..as on a Superflow bench with 28 inches. All within 4% max/min, within 1.1% of average or so, this is untouched right off the CNC. Just for reference 8) I'm getting a 3B flowed right now for comparison 8)
    However the flowbench numbers show me I will never put a RS2 IM on my car!
