Millers and consumption
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    Anyone else here been using fully synthetic 5w 40millers oil in there S2,just wondered about their general oil consumption.
    Don't want to start usual forum debate about what oil to use,although thinking of changing to a silkolene 10w50.
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
  • iain1067
    • 984
    I used to use synta gold for a long time, and found that between 6k oil changes needed a top up, switched to millers using the same grade and no top up needed.
    • bertman
      • Apr 2007
      • 1173
      Am finding I have to top up quite regularly,but well within recommedations.But still topping up though
      Rob
      • iain1067
        • 984
        what grade are using at the moment??
        • bertman
          • Apr 2007
          • 1173
          Using what I put in the first post,have been told that it may be a bit thin for a higher mileage engine.
          Rob
          • Rusty
            • 18953
            Check for signs that the rear crank seal is leaking if there's no blue smoke...
            • bertman
              • Apr 2007
              • 1173
              No blue smoke,what do you look for with the crank seal leaking,visible oil?
              Rob
              • dubmeister
                • 522
                What mileage has the engine done??
                5w40 seems a bit thin.............
                would have thought that a 10w40 would have been a better choice.
                • bertman
                  • Apr 2007
                  • 1173
                  Nearly 151000 at the last looksie
                  Rob
                  • BrianSmith_S2
                    • Jun 2005
                    • 1342
                    • Home: Northern Ireland Current: British Antarctic Territory
                    Go for the silkolene 10w50, its a good spec oil.
                    • bertman
                      • Apr 2007
                      • 1173
                      That's a bit uncanny Brian I have just ordered 2x5 litres of the stuff,not more than 5 mins ago from opie oils
                      Rob
                      • bertman
                        • Apr 2007
                        • 1173
                        Got that much incase the blooming thing needs topping up.But will wait to see if oil consumption improves a bit.
                        Rob
