whistle noise @ 2000rpm ?
  • MGaz
    • Feb 2008
    • 698
    i've noticed that when the engine is just above 2200 rpm i get a 'whistle' type noise, that then vanishes after about another 200rpm over.
    also, i get same noise (but only for a much shorter period) @ just under 2000rpm.
    anyone heard this b4?
    it does it in all gears, so its not the tranny, i'm sure.
    also, if i rev it to just over 2000 rpm while parked, i get a 'ery small' but noticable bit of vibration from the engine, thru the car. (but no whistle)
    The car is a type 85 KV coupe quattro.
    C4 A6 AEL avant quattro: daily
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • MGaz
    • Feb 2008
    • 698
    anybody?
    strangly 2000rpm is exactly spot on 30mph in 4th. Hummm...
    Schrick 272 cam
    ITG filter
