takes ages to get started
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    When I try to start my car it takes a couple of mins turning over. it doesn't catch for a bit. then it catches and dies quickly. Then it catches, runs lumpy, then smooth, then lumpy and eventually all is well. If I try to rev at any point it will choke and die until it's running steady and in that case it's all good. When the car is warmed up I can stop and then start again with no issues. My neighbour suggested a sticky injector or rod so I put a good injector cleaner in the petrol (redex advanced or something along those lines) and let it run for a while. Then later I took it out for a rapid run up the dual carriageway and back home again. I'm not convinced that will be it sorted though.
    Any suggestions very welcome.
    1990 CQ20v
  • Flat on my back
    • Jan 2007
    • 2449
    Fpr?
    Carlos.
    • Knight Rider S4
      • 3541
      As posted on Experiment threadneed to check sensor wiring as ecu does not know he car is cold
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • Nj
        • Jan 2007
        • 3420
        cheers Steve, yeah. heading for temp sensor to investigate.
        1990 CQ20v
        • andyg plym
          • Nov 2006
          • 4646
          ISV? does the revs rise or fall between gear change?
          • Nj
            • Jan 2007
            • 3420
            i'll check that as well mate. cheers. good chance a few things are a bit clogged up after months sitting in a box.
            1990 CQ20v
