Im finishig up on stand alone computer instalation and one of the last problems is the number of teeth on the flywheel on 3B. I have found info that on ABY there are 135 teeth.
Could any one count ??
i would have to have my gearbox taken down
I kneed to know the number to set proper ignition.
form my info they don't, we have counted them with out taking the gear box out ... thought little hole for sensor ... from our count it has 145 ! i kneed somebody to go to the garage and verify that on a spare flywheel
when we used 135 nr the car wasn't stable but with 145 it is
now we are taking MAF out no more problems with that
Sorry I couldn't dig out the manuals last night - can't track down the place where I saw it, but I do know that all the 20V turbo engines have the same number of teeth on the flywheel and the ref sensor is even in the same place. Actually its the same on the old 10V WR engines as well - I have helped guys graft the ABY Motronic system onto a WR engine and the flywheel timing is exactly the same...
