Crankshaft sensor location
  • K7ERG
    • 1711
    Crankshaft sensor location of multi plug on a AAN?
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
    Can't help on the AAN but on the ABY the plugs are behind the engine by the throttle body...
      Craig
      The G4, 034 905 381, igntion timing sender (black) is connected on the firewall rack with the engine speed sensor (grey) and the knock sensors (green and blue) and the coil power connectors, under the black plastic cover.
      You might want to visit this:
      http://forums.audiworld.com/s4s6/msgs/116988.phtml
      • K7ERG
        • 1711
        Found it thanks
        Craig
        07947385043
