fuel filter
  • strapper
    • Dec 2007
    • 170
    fuel filter
    where is the fuel filter located on the s2 coupe? Is it easy t replace?
  • s2driveruk
    • 12696
    look under the car in front of the wheel well of the rear pass side and you will see a canister with a couple of banjo bolts on it....ta da
    Think the bracket can get a bit crusty but easy enough access from memory
    1992 3b S2 Coupe
