Hi all,
Recently, after engine shut down, I could wait by the car and after a few minutes would here a shorting/clicking noise and the sound of the fan coming online, then going off, and back on – etc.
The shorting/clicking sound of the relay could go on for quite a while.
Then, on a different occasion after engine shutdown, the after-run pump would run but without the fan.
Am I right in believing that when the after run pump is running the fan should also be running?
The fan definitely works as I’ve heard it when the engine is running – i.e. – car stationary.
I obviously have a relay problem, but which relay do I go for. There are 2 relays, under the bonnet:
Fan (eng rad) relay
Cooling fan relay
Or, is there a separate relay for the after run pump?
If so, does this operate the fan too?
I know there are relays located inside the car, fwd of the glove box, but have not investigated them yet.
Fan (eng rad) relay
Cooling fan relay
