got an irritating problem (Herbpeas
On acceleration no problem but when you lift off the throttle and let the speed drop (at any speed) there is a squeeky kind of a sound,like a rubbing.
im wondering if it could be either centre prop bearing or engine mounts shagged thus letting the engine move at varios angles?
I cant see it being gearbox mounts. I get the feeling its the prop fouling the zorst heatshield,as the noise seems to be from the centre of the car. If i press the clutch noise goes (hope its not the clutch
) as if engine has moved about to correct position.
Any been there done thats?
) :On acceleration no problem but when you lift off the throttle and let the speed drop (at any speed) there is a squeeky kind of a sound,like a rubbing.
) as if engine has moved about to correct position.Any been there done thats?
