For those who remeber my WOT fault.... with the help of Paul N
and schematics it was resolved yesterday...
Bottom line... caused by a faulty (but only just) baromtertric pressure sender.
The ECU uses a combination of resistance from the throtlle pot and the pressure sensor (which is located behind the UK passenger kick plate) to sense WOT.
After a couple of hours testing with multimeter and breakout box and the usual "mmmmmmm, sounds plausible, but why on earth did they do it like that" S2 logic we swapped the sensor from Paul's car with mine and hey presto overboost through WOT.
Paul will post the resitance values of my duff sensor versus his for anyone (Peter?) suffering similar problems, as well as the Audi and Bosch Part numbers.
If anyone is wondering with the sesnor disconnected the ECU defaults to a set value of 968millibar of atomspheric pressure and the car looks as though it uses overboost cutout protection to prevent excess boost.
The sensor is approx £40+vat from Bosch.
As you can imagine I'm seriusly glad to have it back to 'normal'.
Yes mine's got a similar fault. Don't suppose you can post any pics of that sensor location ? Mine's got the dealer fit air con so things have been moved around in that area.
Wooosh!
