which are the wires on the 6pin-TPS???
  • 20vQC
    • Aug 2007
    • 684
    • Current: Italy
    Buddies! How are you all? Hey I have some problems using some other BOSCH and WEBER TPS's on my VEMS setup... So I decided to use my stock AAN's TPS! But I don't have any idea which is the GND, the 5Volt constant, and the variable 0-5V signal pins of those 6pins it has!
    It's april 4th... and it's snowing over here! 3 inches of snow in the floor! And my Quattro is not over yet
    - Looking for a S2
    - Lancia Dedra HF turbo i.e. (4sale)
    - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
    this should help you http://www.sjmautotechnik.com/troubl.../20vthrot.html
      Fill your boots --->
      Theres also a section on the TPS covered in the Motronic chapter of the Technical pages.
      • 20vQC
        • Aug 2007
        • 684
        • Current: Italy
        Hey Paul! I don't really understand that diagram, on page 4 on the Motronic schematics, in the G69 is the TPS but I don't get which pins are the ones I'm looking for! could you take a look please? What I get is thet pin 4 and 6 are GND, 1 and 3 are for the idling switch which I do not need... I'm confused...
        - Looking for a S2
          Look here for a Motronic diagram showing the F60 idle switch and G69 TPS (all in one unit). The idle switch signal to the ECU is on T52/55. The G69 signals to the ECU are T12/55 and T53/55:
          http://forums.audiworld.com/s4s6/msgs/206801.phtml
          If you go here for the AAN ECU pin-out, you will find that T12/55 is a red wire supplying power to the idle switch, TPS, hall sender, etc. T52/55 from the idle switch is violet. T53/55 (a variable 0-5V) is a grey wire:
          http://forums.audiworld.com/s4s6/msgs/149829.phtml
          (The remainders must be grounds, etc)
          • 20vQC
            • Aug 2007
            • 684
            • Current: Italy
            Woah... I see that! But, I don't have the harness of the AAN, the TPS connector either... So I jut have the TPS and the VEMS harness... I might know which are the pins of the TPS connector
            - Looking for a S2
            • 20vQC
              • Aug 2007
              • 684
              • Current: Italy
              Found it guys!
              Pin 1: 0-5V signal
              Pin 2: +5V
              Pin 3: GND
              The pins 4, 5 and 6 are for the TPS switch, I just know that pin6 is GND too!
              Cheers!
              - Looking for a S2
