Removing RS2 Speed Limiter
P18 of the RS2 workshop manual. Coding 4 applies a speed limit of 270km/h
The limiter can be removed by applying coding 1. disconnect pin 38 from earthMike
http://www.s2-audi.co.ukComment
All the test reports I have in old magazines state that there was a 262km/h 163mph limiter, and that it could be ordered without as an optional extra. The limiter isn't on the speed it self, but on the revs in 6th gear.
Are there any other effects (malfunctions?) on the car if you snip the earth wire as mentioned in the posts over?2007 Audi Q7 3.0 TDI S-line____2003 Audi A8 4.2 Quattro____1994 Audi RS2 2,2T Avant____Audi Quattro Experience____Audi Sportscar Experience
Protected movement - with quattroComment
Hello you guys,
Thanks for the prompt answer to my question! My car certainly has a limiter, since I´m running 1.6bar boost on the original K26 and It stops at 270km/h (on the clock, that is) like hitting a wall!
I was told about that pin cutting thing, though I was a little bit worried about the consequences of doing that. Didn´t know if it was going to cause me any trouble with the ECU, so I thought it would be a nice idea to ask on the forum if anyone has done that!
So, the thing is: is it safe to cut pin 38 to remove the limiter, then? Has any of you guys already done that? Any help will be much apreciated since even the Porsche dealer around here seems to be unaware (or unwilling to tell) of that!
Best regards
NiloComment
did you find out anything Nilo? I want my limiter removed as well.2007 Audi Q7 3.0 TDI S-line____2003 Audi A8 4.2 Quattro____1994 Audi RS2 2,2T Avant____Audi Quattro Experience____Audi Sportscar Experience
Just remove the coding plug attached to ECU wiring loom - inside the Apillar on passenger side near the ambient/altitude sensor.Paul Nugent
I agree as Mihnea said something similar to me when mapping my car. In fact he even set it at 40 mph for a minute or two to wind me up!
It worked too, the cars ignition was cut at 40 mph. My car has now been set at an untouchable 199 mph
RS2+ (now sold...)Comment
Just gave my RS2 the beans last night, bang on to the speed limiter!
I was a bit surprised! I would have thought the MTM chips would have got rid of it!Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
Dunno WTF you need to do that... Just remove/hack the coding plug so that the ECU is placed into CODE 1 state. That is how the ABY is setup - nothing attached to coding plug.
For example - look at S2 wiring for coding plug (T6d) - pin 38 is just open circuit when code plug is not fitted.
No ****ing need to remove ECU pin 38 with a ****ing hatchet !!!!!!!!
PaulPaul Nugent
