Engine mount Rubber or oil ?
  • andyg plym
    • Nov 2006
    • 4646
    I recently ordered an offside engine mount. When i got there (GSF) they had ordered the wrong one,there are 2 types: Models with Aircon,and ones without.
    My avant has aircon and i took the mount anyway with the proviso that if it was no good id return it.
    The mount i got was solid rubber,very heavy duty as you'd expect.
    Question is will it be alright?
  • BrianSmith_S2
    • Jun 2005
    • 1342
    • Home: Northern Ireland Current: British Antarctic Territory
    Where does the "Rubber or Oil" come into it? or was that text really meant for the girlfriend
    • andyg plym
      • Nov 2006
      • 4646
      they said there are 2 different ones,rubber and oil,ive read in threads there are some that use oil........
      • quattronutter
        • Jan 2005
        • 690
        solid or oil filled
        • andyg plym
          • Nov 2006
          • 4646
          Originally posted by quattronutter
          solid or oil filled
          Huh??? The one i have is solid rubber.
          p.s quattronutter i have been told to see you for advice on wheel bolts....
          • quattronutter
            • Jan 2005
            • 690
            most likely for s8 wheels
            • Mikes2
              • 1704
              Check your GSF receipt.
              It should contain the Audi OE number of 8A0 199 382 D. A C suffix is for non air con cars.
              It's listed as a hydro mount which suggests it's oil filled.
              Mike
              http://www.s2-audi.co.uk
              • stiglet
                • Aug 2007
                • 1264
                I have the solid ally 034 ones and they aren't too bad
