a) Hello guys! Does anybody know anything about the stock coil packs??? I needed to take out all the coils from the plate that says 20V TURBO and puth the coils separately from the engine to avoid heat and misfires!!! Well, for the electric part I'm a little confused. So, each coil should have the 12V and ECU signal wire inputs, then the GND and the HIGH VOLTAGE outlet.... am I right?
b) Ok, the 12V wire (I'm not 101% sure) but would be designated in the coil with the #15, and the signal is #1. The GND is situated one the plate that the coil rests. Good??
c) On my VEMS setup I have 2 wires that send the continuous 12V power supply and then the 5 ECU SIGNAL wires that goes for each #1 input on each coil pack. I was putting together the 12V PS in a TWO-pin plug. The coils 2,3,4 (#15) to the first pin of that plug, then the coils 1 and 5 (#15 too) to the second pin. That way I have a TWO PIN plug for the power supply.
d) For the ECU signals, I used two 3-pin plugs. The first one has the #1 of the coils 1,2,4 and the second one has the 5,3 signals... Now those 3 plugas will be connected to the wires that comes from the wire harness.
My question: IS THAT A SAFE INSTALLATION? OR WILL I BURN ALL THE COILS AS SOON AS THEY GET THE CURRENT?????????????????
thanks in advance,
Fabio G.
thanks in advance,
Fabio G.
and have original coilpack gathering dust in garage, I could try to remember to dismantle it a bit tomorrow. I think I should be able to check my thoughts about them against yours. Do you have igbt's in your vems and can run without the original POS?
It works exactly the same as any other ignition system.
