Cooling system of doom
  • Paulgo
    • Jan 2005
    • 498
    Originally posted by shark_90
    found the leak on the rad which turned out to be coming from the mounting at the bottom. The reason for this being I was missing a metal bracket + mounting from the front which I didn't know was even meant to be there!
    Quick hijack, but out of curiosity what was the metal bracket like? Ive just got rid of the old horrible Nissen rad for a proper one and an L shaped bracket fell off the lower mounting somehwere when I was removing the old rad before I could see where it came from. Didnt seem to serve any useful purpose so I left it off and everything seems fine... but you got me wondering now!!
    cheers
    Paul
    • Big Lee M
      • 2571
      Your the lucky one shark 90, i had the same problem but my head gasket has gone!!!!!!!!
      Glad you got it sorted buddy
      Just some finishing touches to do now
      • shark_90
        • 1475
        Originally posted by Andy_Casey
        Good work, that bottom bracket on the Rad went on my old NIssens one. 200 notes for a new rad is a bit steep, where was that from?
        Derby TPS - and that was with discount. Retailed at about £250 I think.
        1994 Audi S2 Avant - in pieces
        2006 Skoda Octavia vRS 2.0TFSi - goes fast
        1985 Audi 90 quattro - is wet
        Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
        • shark_90
          • 1475
          cheers
          Paul
          Here's a pic of the bracket I was talking about:
          • Paulgo
            • Jan 2005
            • 498
            Cheers mate - thought you meant that one as I couldnt see how the other bracket I meant could effect anything, other than not providing enough support at the bottom!
            The only problem I had with the one in you're pic was getting the little rubber bobbin (where it screws to the rad housing) off the old one. Seized up solid so just left it. We had to make a replacement from an old grommet as I belive it needs to be able allow a little movement to absorb shocks on that brace etc.
            cheers
            Paul
