What a day. Started at 9 this morning:
Plan was to replace turbo and do engine mount at the same time,then rocker gasket.
Started by drenching everything in lube spray to make the bolts easier to move,
then took all the nuts off the exhaust and turbo,couldnt be bothered to get under and undo the downpipe so got the lady to gently prize back the exhaust from turbo with a shovel
Undid all the pipes under and on top,this wasnt that easy as theres no slack in the pipes and as you all know no freakin room!
Eventualy got it off and then examined the engine mount....FEK!!
The arm had sheared away from the block.....NO!!!
Managed to bodge it and is now back on just with 2 bolts...will have to do for the mo.
Trying to align the arm back up was a joke,you just cannot see what you're doing with the manifold in the way,i battled on as the lady kept bringing tea out.
Now time to bolt up turbo,wasnt too bad,again i did it all from above (i read it was easier to do underneath),then the rocker gasket,then all boost pipes.
Fricken weather was a joke too,had to keep dodging the showers.
took me 10 hours all in all,now need a
