Need a bit of help. Car was working fine on Sat morning when I left it the pub carpark to go and play golf. Left it there overnight while I had a few drinks. Went to pick it up yesterday afternoon. It started initially, but only for a second, cut out and then wouldn't start. No problem with battery, engine turned over easily but didn't appear to fire at all. Went back later with a few tools, took the coil cover off and a plug out. Very faint smell of fuel on the plug, not as much as I would have expected. Connected the plug to the coil pack, turned the engine over and there is a spark.
I'm guessing it's fuel related, possibly the pump which has been whining (not overly loudly) for quite a while. I was going to check it, but when I lifted the the back seats, surprise surprise, no pump. That's because it's an avant. I now realise the pump is in the boot.
Anybody have any other suggestions as to what it may be? What else should I check? What's the best way to check the pump?
I have a new 044 pump which I've never got round to fitting. Is it the same fitting kit as the one listed in Greg's how to for the coupe?
Any help gratefully received.
Alistair
Alistair
